Deployment triggers (Automation for Jira)
Curt Holley
Hi
I'm trying to help a team (that have a release pipeline interacting with Jira currently) with some automation to transition the relevant story/s to Done upon completion of a successful deployment.
But we are struggling to work out what the Environment Types represent in the " Deployment Successful" trigger option.
We have data coming through showing the "environment name" (which are the Stages in their Azure DevOps Release Pipeline) but how do we trigger the automation via these "environment types" in the trigger? Env name.png
Curt Holley
Thanks @tomas but that much I knew. What I was after was how that is mapped from Azure DevOps.
The answer; via "Deployment type"
Osama Abdul Ghafoor May 6, 2023
Hi @Curt Holley I am also trying configure and enable Deployments Feature in JIRA. I am using Azure DevOps release pipelines and it the release pipelines I have checked out the option "Report Deployment Status to JIRA" but unfortunately I am not receiving any deployment status back to JIRA
Can you help me out on what worked for you while configuring Deployment feature in JIRA?
I have posted a question in the community as well.
mohammedghouse
October 8, 2021
How to use deployment variabale in another build plan where i am i use trigger this deployement
tomas
February 25, 2021
So this environment is used to distinguish for which environment we want to trigger the automation rule.
So when we select `production` the rule will only trigger the rule when a commit is deployed to production.
