Difference between local and AD users as Jira system administrators
Vladislav Pavlovic September 11, 2013
In our Jira setup we have one local user and few AD users that are part of group with JIRA System Administrators Permissions. We noticed that AD users as administrators have less permissions then local Jira user.
Is that normal behaviour? If it is, can it be changed?
Vladislav Pavlovic September 26, 2013
It was a misunderstanding. I have found no more differencies.
Bruna Griebeler
September 26, 2013
Well a Jira Admin that comes from LDAP will have less permissions regarding User Managment. It will not be able to change the LDAP directory, since he is part of it.
What other differences have you noticed? Something missing on the Jira Admin panel maybe?
Vladislav Pavlovic September 24, 2013
No more differences has been found.
Vladislav Pavlovic September 18, 2013
I am sorry for delay.
It was misunderstanding with my colleagues.
Yes, there is a difference: you can't edit AD user directory when you are logged in via AD. Jira gives warning about this and that is a rule. I haven't found any other difference.
Raffaele Verre September 11, 2013
No, is not a normal behaviour ... check the local user group
Florin Manaila
September 11, 2013
Perhaps it would help to know what permissions are they missing and how are those permissions granted (to whom)?
Christian Czaia _Decadis AG_
September 11, 2013
Are they all execatly in the same groups, roles etc.? Other than that there shouldn't be a difference...
