Disable INFO log for mailfetcherservice in JIRA - how ?
Mik
Hi Guys,
Do anyone of you know how can I disable INFO log for mailfetcherservice (Incomming email handler) in JIRA?
2017-11-30 08:30:54,232 Caesium-1-4 INFO anonymous Test [c.a.mail.incoming.mailfetcherservice]
Thanks for any help.
Regards
Mik.
Andy Heinzer
December 1, 2017
Hi Mik,
Not all packages in Jira have logging that you can configuring with in the application natively.   However what you can do is try to see if you can set the specific logging level for that package to see if this works.  To do this, you would need to first navigate to the Logging and Profiling page in the System menu.  In order to reach that page you need to be a system administrator in Jira.   The URL is your JIRAURL /secure/admin/ViewLogging.jspa
From there under the Default Loggers section, you will see a link for Configure level for another package.   Click that link and then try to enter the package name
com.atlassian.mail.incoming.mailfetcherservice
From there you can try to set the level to something other than INFO, such as WARN or ERROR.
I say try, because as I mentioned not all packages can you set logging for natively.   If this works, great, but if this does not work, then you might have to set this level on a parent package like:
com.atlassian.mail
OR the other more complicated alternative would require you to edit the source code of Jira in order to enable logging of that package in the log4j.   That process is not as easy to accomplish in all versions of Jira as currently there is a know problem with certain versions of Jira that cannot be built from the publicly available source code due to a bug.
But try this package or the root package and see if that helps.
Andy
Mik
Hi Andrew,
Thanks a lot for your post.
I think that what you suggest is close to solving the problem.
Unfortunately, it was not possible to save the given packages in JIRA ( I have version 7.2.2) in Logging and profiling.
Temporarily disable unwanted logs by "Disable the Incoming Mail log."
Regards
Mik
Nikhil December 8, 2017
Issue Resolved
IT Administration
January 15, 2018
Hi everyone,
we had the same problem and were able to resolve it by editing the
log4j.properties file
in C:\Program Files\Atlassian\JIRA\atlassian-jira\WEB-INF\classes
and restart the service
2018-01-15 10_15_44-ASGRD - ASG-RemoteDesktop 2017 - JIRA t.serv Prod. APPGAJP02.png
Maybe setting the log4j.logger.com.atlassian.mail.incoming to WARN is enough, idk.
You might wanna test it out.
I can't to this in my productive environment right now and the development system isn't getting any mails and therefore doesn't have the problem...
I hope this helps.
Best regards
Caroline
