Comments isn't actually a field. There's a different rule set. You would want to use the comment on Issue rule
Best,
Clark
@Clark Eversonunrelated question - are you using a browser plugin to use dark mode?
Comments are not a field, they are a set of data you add to an issue. You cannot edit comments during a transition, only add a new one
thank you all for the clarification.
But how could it be possible to have default values already prefilled in the pop up "comment" field screen when issue transitioned. ( using automation for Jira)
what I mean is that:
when issue transitioned, the popup screen of Comment field, that displays, should content a default values already prefilled.
Thanks You.
No, there's no way to pre-fill a comment (why would you? People will just accept that you've prefilled it, ignore it and you'll end up with thousands of meaningless comments telling you nothing of any use)
HI @Charlie
Just to add to @Nic Brough -Adaptavist- , in the transition screens, the comments fielde is there by default all the time and that is why you cannot select the field.
