I want to fetch data of a field in issues from JIRA to an external Java application. Below is the simple java code written
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.URL;
public class JiraIssueDescription {
public static void main(String[] args) {
try {
URL url = new URL("https://****.atlassian.net/rest/agile/1.0/issue/41459");
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("GET");
conn.setRequestProperty("Accept", "application/json");
conn.setRequestProperty("username", "***@abc.com");
conn.setRequestProperty("password", "****");
if (conn.getResponseCode() != 200) {
throw new RuntimeException("Failed : HTTP error code : "
+ conn.getResponseCode());
BufferedReader br = new BufferedReader(new InputStreamReader(
(conn.getInputStream())));
String output;
System.out.println("Output from Server .... \n");
while ((output = br.readLine()) != null) {
System.out.println(output);
conn.disconnect();
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (IOException e) {
But when I run the code I get connection errors.
java.net.UnknownHostException: ****.atlassian.net
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.security.ssl.BaseSSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
Can anyone please help me with the errors. Do I have to implement authentication for rest api requests?
Hi everyone, the issue got resolved by the below java code. Hope it helps. It uses Basic Http authentication.
probably the URL is incorrect. The correct URL for your rest is
("https://****.atlassian.net/rest/api/2/issue/41459");
for more information read here (https://developer.atlassian.com/cloud/jira/platform/rest/#api-api-2-issue-issueIdOrKey-get).
About authentication you caread here https://developer.atlassian.com/cloud/jira/platform/rest/#authentication
Fabio
Hi Fabio, I have the below URL with Postman and I'm able to get the response.
Also, I've tried with the URL suggested by you, but its giving the same error.
P.S. Thanks for the suggestion
