Field not displaying in Issue Collector
rmax
I've added some fields to a project and only some of them are displaying.  I cannot get the other field 'Location' to display.  I've checked the configurations and screens over and over and all the other fields and Location are there yet in the Issue Collector, it doesn't display.  My aim is to add fields and make them required for the Issue Collector form.  Thanks
rmax
I think it is related to the type of field it is.
Samuel Gatica (ServiceRocket)
Hi @rmax
Check if the field Location has a Context field that may prevent it from showing in the collector.
Best regards
Sam
rmax
Hi Sam, thanks for your reply.  There weren't any Contexts but I think it is related to the type of field it is.  I've tried other ones and they all display.
Hi @rmax
What type of field are you trying to add?
