Fire Custom Event Whenever Custom Fields are modified in JIRA
D April 2, 2014
Hi everyone,
I'm trying to send email notifications whenever custom fields are modified. For example, I'd like to notify the developer whenever he/she is assigned to an issue. Note: the email notification should not require a transition. Therefore, I don't believe I can use post-funtions to fire off the event.
Any straightforward ideas?
Dotun
Nic Brough -Adaptavist-
April 2, 2014
You will need quite a lot of customisation in a listener. Changes of field just fire "issue updated", so you'll need to shut down the existing notifications and code ALL of the logic for "who do I send email to when I catch an issue updated event"
As Jobin says, assignee is different, using "assign issue" fires issue assigned events (but not if you change it in an edit screen) and there are some others like work logs and comments that fire different events too.
Jobin Kuruvilla [Adaptavist]
April 2, 2014
You can do this using the ISSUE ASSIGNED event. Won't that work? And for custom field updates, you can use ISSUE UPDATED event.
If you want to get notified only for certain fields, then you will need to write a custom listener.
D April 2, 2014
I want different people notified for different fields. Would writing the custom listener work even without transitions?
