Hello all, I'm trying to automate a process in Jira based on actions in GitHub. When a PR is approved in GitHub, I want that to automatically approve the associated Jira issue. The issue is designated by the "[ABC-123]" tag in the title of the pull request.
The connection is established and the development panel shows up with pull requests, commits, and branches. But I can't seem to query the development panel and I'm not versed enough in creating a GitHub action.
Hi! I'm the community manager at Exalate.
It looks like you’ve already found a solution—great to see! That’s a solid approach—parsing the summaryBean
structure directly gives you access to detailed PR data. One limitation, as you noted, is that scripted fields don’t trigger issue update events on value changes, which makes it tricky to hook into workflows. Just in case, there are several tools that can help you achieve this setup.
You can explore available options here: Atlassian Marketplace
For example, with Exalate, you can detect the pull request approval on the GitHub side and map that to a status change in Jira. This gives you full control over how and when the data syncs between platforms.
To access information in the 'Development' panel on a Jira issue linked to GitHub, you can use ScriptRunner. Here's how I figured this out:
I haven't quite figured out how to run a workflow off of it yet though. The value changing for the scripted field doesn't push an update issue event.
