One of our forms, we have a date field for the user to have a task finished on. How can I make our Jira instance write an internal comment of our choosing on that specific date? I was poking around past forms and it looks like I cannot do this OOTB.
If you have access to automation (Project Settings -> Automation), you can set up a "Scheduled" Rule to run everyday, and:
1. Run for all relevant tickets (you can use JQL to fetch them)
2. Check if {{now.jiraDate}} equals the value of the custom field.
2. If yes, add a comment to the ticket.
Hope that helps!
Interesting approach! Would this become resource hungry after a bigger amount of tickets coming through? Or maybe change the conditions to check every ticket X days prior to todays date only, then run your suggested condition?
You can use JQL to pare down the number of tickets that are fetched - something like
customfield_value = {{now.jiraDate}}
Then you won't need the check as well since only those issues with the field value = today will be returned.
