×hi, community!
i'm trying to write automation rule, that creates issue
every 2 weeks on tuesday, at 11:20
basic functionality supports time like 11:00 or 11:30, and doesn't allows to set time 11:20
i'm creating CRON like
0 20 11 ? * 2/14
but receiving error "The step interval for day-of-week must be less than 7: 14"
is there another way to make 2weeks-step?
thank you!
the easiest way that comes to my mind would be to set the cron to weekly and add a condition right afterwards that checks the checks for the week (eg. calculate if it‘s odd week and only run rule if the condition is true).
Hope this is helpful.
Best
Stefan
In case this solves your problem please consider to accept the answer. This makes it easier to find the solution for other people facing the same/similar problem.
Thanks in advance.
Best
Stefan
Looking at that expression and the error, the rule is noting your values for Day-of-Week are out of range, as 14 is greater than 7 days in a week.
Please take a look at this page which shows examples that match what you wanted:
Hi @Chasovskikh Kirill There is no cron expression for every 2 weeks. You can use following CRON :-
0 20 11 ? 1/1 TUE#2 *
RUN AT 11:20 EVERY MONTH TUESDAY 2 OF EVERY MONTH
If Above doesn't work try this one :-
0 20 11 ? * 3#2 *
At 11:20:00am, on the 2nd Tuesday of the month, every month
Seconds | Minutes | Hours | Day Of Month | Month | Day Of Week | Year |
0 | 0 | 0 | ? | * | 3#2 | * |
http://www.cronmaker.com/;jsessionid=node01vvidrxxqkbgre44hiri8snz0381389.node0?0
V.Y
