Help with an automation: Copying the "assigned" person to a "People" field in the issue.
David Martinez Moreno
In my issue type I created a "people" field called Blank done by.
When an issue is transitioned to a certain point, I want the person who had the issue assigned to be copied to the "people" field Blank done by.
Why is this not working?
Bill Sheboy
January 16, 2024
Hi @David Martinez Moreno
Would you please post an image of the audit log details, showing the rule execution?  That may provide some context for this symptom.
Until we see that...
You note a "People" field.  Are you using a team-managed project?  You may find this information at the lower-left side of the page's expanding area.
If so, there are some challenges with accessing People fields in automation rules.  One possible work-around would be to use and advanced edit with JSON to copy the value.  Please look at this reference to see the syntax, based on if you are using a single-select or multiple-select user field: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Multi-user-picker-custom-field
And, to do that you will want to identify the custom field id, or exact smart value, for your field.  Please look here to learn that: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Deivid Araujo
January 16, 2024
Hi!
Try this:
{{issue.assignee.accountId}}
Thank you. Still no luck with {{issue.assignee.accountId}}
also tried {{issue.assigned.value}} Also no luck.
Somehow nothing appears in the Blank Done by field.
Tried all of these:
{{triggerissue.assignee}}
{{issue.assignee}}
{{issue.assignee.displayName}}
{{issue.assignee.value}}
None of thses actually capture date in a "People" custom field.
In other custom fields, for example comments, the
{{issue.assignee}}
Do return results, but then again, in a "people" field, nothing appears, as if looking for this person finds the person but does not click the checkmark to input the value in the People field.
