Hi All,
We installed the Insight Asset Management app from marketplace free version. In order to checking we created the sample schema , object types , objects , attributes and custom field.
In project screen we added the created custom field and the issue screen (agent view)we able to see the objects.
Now the problem is we are not able to see the CMDB In Insight Asset Management app.
Please guide us what is CMDB? and what is the use of this?How it is helps to Insight Asset Management app? How to setup this into Insight asset app?And also what is Event Management and what is the relation b/w event management to CMDB?
Thanks for evaluating our solution. I will be happy to clarify your questions. You can reach us via sales@mindville.com
Best Regards,
Hakan Bahadir
Mindville
