How do I create a linked issue using a HTML link?
qbitops
November 19, 2015
I've been trying to create a new issue linked to a parent issue by generating an HTML link, based on the guide here: https://confluence.atlassian.com/display/JIRAKB/Creating+Issues+via+direct+HTML+links
HOWEVER, JIRA seems to be ignoring the issue key, even though it's valid. The URL I'm using is this:
<base-url>/secure/CreateIssueDetails!init.jspa?pid=10101&issuetype=1&summary=hello&reporter=<reporter>&issuelinks-issues=LA-144&issuelinks-linktype=blocks
Interestingly enough, when I pass an INVALID issue key, it adds it to the list box and then complains that the issue key does not exist:
<base-url>/secure/CreateIssueDetails!init.jspa?pid=10101&issuetype=1&summary=hello&reporter=<reporter>&issuelinks-issues=yo&issuelinks-linktype=blocks
Generating this error:
So obviously I have the right query parameters!
Levin_Oertle
February 24, 2020
I still have the same Problem.
The workaround is okay but far from good...
Johan_Sleman
March 2, 2020
Could you please share your workaround?
Rob Fagen March 2, 2020
It was down below from Dec 11:
Same problem here. One workaround that I found, and might work for you:
&description=relates+to+<issue-key>
or
&description=blocks+<issue-key>
It converts a valid issue key to a link.
It's a workaround in the sense that it at least makes a clickable reference to the other issue. It's not a workaround in that it doesn't leverage the searchability of the normal "linked" field. If you're consistent about the description you add, you can add to the JQL expression:
text ~ "blocks <projectkey>"
or
text ~ "relates to <projectkey>"
in order to pull up all the issues you've updated this way.
CJ Edwards
CreateIssueDetails!init.jspa?pid=12345&issuelinks-linktype=relates+to&issuelinks-issues=${issue.key}&issuelinks-issues=A-1 ...
 I put in the first issueKey i want, then I add another issuelinks-issues= with a bogus issue to make the field populate
this does cause the error to fire, but at least the real issue does get put in place as well.
Rob Fagen December 9, 2020
Oh! Clever! That's some real outside-the-(dialog)-box thinking :)
You could name the 'fake issue' as "Please_Remove_Me", maybe?
Thanks!
Johan_Sleman
February 28, 2020
CreateIssueDetails!init.jspa?pid=10700&issuetype=10622&summary=hello&assignee=user&customfield_11825=10551&issuelinks-linktype=includes&issuelinks-issues=PP-535
Having the same issue, the link only seems to be added to the "Issue link" box if its an invalid issue key. Has any one figured this out yet?
Antek Grzanka
April 29, 2020
did you manage to find a solution? running into the exact same issue
Nadav Dahan
September 9, 2020
Joining @Antek Grzankaquestion. Did anyone find a solution to enter a issue in the"Issue" field of linked issues through html url?
Rob Fagen December 11, 2019
or
Martin Ofner
July 1, 2019
I'm running into the same issue. Any ideas? Issuetyp number is correct according to metadata.
Ray DR
It did not like the 1-4 issuetype numbers for me either. You will have to pull it from the metadata generated from:
<base-url>/rest/api/2/issue/createmeta
It will likely be 5 digits in length.
atlassian, loom for marketing, sprint planning, marketing team workflow, loom usage, async video messaging, marketing collaboration, jira and confluence, remote marketing, team productivity tools, workflow transformation, atlassian learning
Run smarter, faster campaigns with Loom
Campaigns move fast. When teams are spread across time zones, you can’t afford to waste precious minutes in endless meetings – so what’s the solution? Join Sarah Brown and Jesse Feldman to see how ServiceRocket’s marketing team uses Loom to get sh*t do
Register now
Upcoming Jira Events
