I'm a software developer who uses JIRA on a daily basis. I created a filter, but named it badly when I saved it. I was able to copy it under a new name and fix the criteria, but I want to delete the original filter now. The Atlassian documentation is of no help because what it describes is different than my interface.
How can I delete a bad filter from my filters list? I can find no filter management ability in the "new, improved" interface and clicking the JIRA icon only shows me a project dashboard, with no option to get to an configuration settings. Can anyone help me get rid of one stupid filter?
That is how you can delete a shared filter, if you have the Jira administrator permission:
https://confluence.atlassian.com/adminjiracloud/managing-shared-filters-818578900.html
To delete your private filter open the magnifying glass icon and then choose the View all filters option:
After it you will see a list of your filters. You will be able to delete any of them.
Sorry, my JIRA doesn't look much like yours: clicking the main icon shows me a dashboard. I did eventually open the Search action. By scrolling down through all the options, there was a *View all filters* option where you said it would be, but it wasn't on the visible page. It was difficult to find.
I dug around a little more and found a different *View all filters* option on the Issues and Filters tab. Again, it was hidden way down at the bottom where I had to scroll to see it. I was able to bring up the list of all filters, as you mentioned. Clicking on the ... button next to my filter, I was able to activate the Delete option to finally get rid of the bad one.
Thanks for your help.
Damn, this new interface sucks horribly.
Thank you for posting this, this helped me clean up my saved searches! You rock!
Thanks for posting this information.
Updating as of 02/08/2023:
For Jira Cloud, I can delete filters via 2 ways:
1.- Filters > View All Filters > ··· on the right to each filter then Delete (if you are the owner, otherwise you will have to change the owner to yourself then delete).
2.- System > Filters > Manage Filters > ··· on the right to each filter then Delete Filter (if you are the owner, otherwise you will have to change the owner to yourself then delete).
The only way I can find to resolve this issue is to mark the issue as a favourite, go to the favourites listing and then the gear icon will appear and you can delete the filter.
Same here. That is terrible!
I still cannot believe this is the only option. But up to now, I couldn´t figure out another way:-(. And I did not find the option 'View all filters' that Ed described. I´m not on confluence, however. We use server
Thank you for this thread - I was going crazy trying to delete filters that were automatically created when I created temporary scrum boards. In the end, all I had to do was select Issues->Manage Filters and then click on "My" on the left side to see filters I created...then do the gear dropdown on the right and select delete. It's always clearer after there's a solution lol...
With scriptrunner you can do something like
No go. I was able to select the bad filter, but there was no *more (...)* button. Even the filter's Edit screen had nothing helpful where you would absolutely expect to find it.
As I stated to Alexey below, I eventually found a View all filters list with *...* buttons. They had a Delete option in the menu that I was able to use.
Makes you wonder if anybody at Atlassian ever tried to use the new interface. It takes several clicks to do anything, where the old one had important actions immediately available just a click or context menu away. Do you know any way to get the old, useful interface back?
Thanks for your attempt to help.
It took me 30 minutes - I finally found it too.. have to agree the interface is terrible. Not intuitive at all. I opened the filter I wanted to delete. Then I went to Issues --> more... and was able to then select the gear icon and delete.
Intuitively, one should be able to delete filters via the "Manage filters" or "Search Filters" functions, but this tool makes you stumble through and finally succeed by selecting "Filters, more..."
It is Sept. 2020 - still not intuitive.
