How do I unflag an issue with Jira Automation?
James San Jose July 26, 2023
Hi
Currently, I have a rule when an issue is marked with a custom status of "BLOCKED" the issue will be flagged. I am curious, if it is possible to "unflag" the issue using Jira Automation? That way I have a rule that is To Flag(as stated earlier and seen on screenshot) and To Unflag(what I want to set up).
To note, I did create post function in the workflow that clears out the flag when it transitions out of that custom status. Although that is not what I am asking about.
Tim Perrault
July 26, 2023
Hi @James San Jose
Unless I am missing something, just do the opposite. Change your trigger to when you want it to happen, set a condition for flagged issues, and then edit the issue field again and remove the flagged option.
Thanks for the quick response and Ill try it out now!
Here is the new rule based on what you stated...
Like Tim Perrault likes this
Tim Perrault
July 26, 2023
Looks good. Let me know if you encounter any issues.
Like James San Jose likes this
Thank you for your assistance on this one!
