How can i migrate a project in Jira service management cloud (free) to on other tenant cloud Atlassian (with premium licence) ?
I've seen a migration tool but it doesn't seem to include Jira Service Management. Is there another solution?
Thanks in advance for your help,
Regards.
Hi @UMONS
I found this ticket which say that JSM is not supported in migration assistant tool (https://jira.atlassian.com/browse/CLOUD-11337). As a workaround Atlassian is pointing to use site export and site import feature in order to import Jira Service Desk projects to a cloud site.
Seba
Hi UMONS,
You might want to try the Revyz Configuration Manager for Jira app in the marketplace. If you want to move the configuration AND the data, then try the Revyz Data Manager app. You can do a free trial do the move. Full transparency - I am an advisor for the apps.
