I am using LDAP and looking to setup dual authentication on my Jira Service desk, what are the steps to setup? any another app required to enable it?
Are you looking to set up 2 factor authentication? Ideally you rely on what identity provider (LDAP) provides, otherwise check out:
https://marketplace.atlassian.com/apps/1213472/secure-login-2fa-jira?hosting=server&tab=overview
or
Can you expand on what you're trying to do? Are you looking for the customers to have a different ldap configuration?
