Hi all,
I wonder if I can achieve the following:
We have a custom field with a predefined default value. The default value is a text. As the field is related to couple of projects we need the text to be changed according to the project, i.e. in one of the sentences automatically to have the project key - *AS A* <Who is asking for this? eg. US HR team>
This eg. US HR team to be replaced with the project key.
Can we achieve that somehow without creating custom field with different default value for each project?
I tried with *AS A* <Who is asking for this? eg. {{issue.project.key}} team> but without success.
Thank you in advance for your help!
For cloud i didn't try a plugin before to do the same
but instead of having a different custom field , i recommend to use context value like below image where you can add different default value per project
Thanks in advance
Mohamed
