×Hi,
I'd like to add permission (to work on and see issues) to issues where Custom Field "Position" is - lets say - "xx". When the field is "yy" it (issue) should be hidden for this user.
Is it possible without coding?
Thank you in advance
Urszula
Nope, you can not add/apply the permission-based on Custom Filed.
Jira does not have field level security but might be https://marketplace.atlassian.com/apps/23216/field-security-plugin-for-jira?hosting=server&tab=overview add-on helps you.
Please have a look at this.
Hi
We also have similar situation where we to grant the edit permission to one of the custom field to specific user/group.
Is there any option in Jira ver 8.?
No. 8 does not do this and Atlassian have said they're never going to implement anything like it.
No. Jira has no field level controls like that. You will need add-ons or coding to achieve it.
Hi!
It's possible but requires some action and it wouldn't be handy to use.
You should:
Note, that this field wouldn't be visible when you "View" or "Edit" the issue. It only becomes visible/editable when you perform this special transition.
Hi, to many users to make such a changes... but thanks a lot.
