Hello everyone,
I need help in order to create a filter that will start on Monday and reset on next Monday, for example:
created >= startOfWeek("+1d") AND created <= endOfWeek ("+1d")
but I need for the filter to show me results from a specific timeframe. For example, from Monday to Sunday to show results between 8 AM and 11 AM.
Thank you!
Hi @Vlad Manolache ,
Jira's JQL doesn't have a direct function to specify time ranges within a day. try following JQL which approximates the time range within the day based on timestamps.
The startOfDay("+8h") and startOfDay("+11h") are indicative and might not precisely represent 8 AM and 11 AM in all scenarios due to timezone differences or issues created at the exact start of that hour.
(created >= startOfWeek("+1d") AND created <= endOfWeek("+1d"))
AND (created >= startOfDay("+8h") AND created <= startOfDay("+11h"))
Adjust the time range and constraints based on your specific requirements and timezone considerations.
Bhushan
Hello Bhushan,
Thank you for your answer and instructions.
Best regards,
Vlad
