×I have an Insight custom field that allows multiple objects to be selected.
Is there a way to filter issues that have more than a single object chosen?
I don't think this is possible with any of the built-in features.
I think some custom JQL function (such as can be developed with scriptrunner) or a customer scripted field that returns a count of objects in the custom field would be required.
You would have the same response if you were asking for a JQL where more than one Option in selected in a Multi Select or Checkboxes custom fields.
