How to implement regular reminders in Jira
Zuzana Zoubkova
April 22, 2016
We've been currently looking for a way how to deliver reminders on a particular schedule, which is issue specific. We have added custom fields ReminderDate and ReminderFrequency (daily, weekly, bi-weekly, monthly). Based on ReminderDate we look for issues using JQL search and send a reminder to assignees - all team members are subscribed to the filter. We were hoping to update ReminderDate field with a new value according to value of ReminderFrequency using JIRA Automation plugin. This way we would be able to remind assignee on regular basis. Unfortunately this operation seems to be currently unsupported for date fields :(
Can you please help me with our use case? How to accomplish this with JIRA Automation plugin?
Matej K
April 24, 2016
Have you tried https://confluence.atlassian.com/jira/how-to-update-custom-field-values-during-workflow-transition-310378700.html and updating the date time field in the workflow? You'd introduce additional workflow transition just to do this but it should work smile
Otherwise you'd need to implement your own Automation plugin action in JAVA, or use ScriptRunner and implement that in Groovy.
Zuzana Zoubkova
May 13, 2016
Hi Matej, thanks for your suggestions. We haven't tried those plugins yet. We would need to ask for installation of them first and it's kind of long process in our company. I will investigate implementation of custom Automation plugin actions smile
