In the "Legacy" system it is very easy to set up a rule where if a Customer replies to a status that is "Waiting" on them (or Resolved) then it will reopen.
This rule does not trigger for internal comments - only if the currently posted comment is public facing and the user posting the comment is a customer.
I do not see any "if" conditions to this effect in the new Automation system.
I was hoping to transition this Legacy rule to the new Automation system, but this is a blocker for doing that.
Can anyone please advise how to handle this in the newer Automation system?
Hey @Bridget Maloney ,
I'm using user condition for this kind of situations. You can choose "user who tiggered the event" "is a customer"
Awesome, thank you so much @Ezgi Bayındır ! I believe that will do the trick :D I have this updated in our Automations and will test it out in the upcoming days
you're welcome! happy to help!
Hi @Ezgi Bayındır I wound up having to roll this back because it wasn't quite doing what we needed. As a result, I am sorry I had to mark it as not answered.
We have people who are listed as customers, so that the true customers can @ mention them, but when they leave an "internal" comment it is actually updating the status.
We _only_ want public facing comments to change the status.
In another instance, we had a true customer leave a public facing comment but it failed the customer check for some reason (she is truly a customer).
Do you know of another way that can look at the internal vs public facing nature of the comment itself?
For agent side you can use
{{comment.internal}}
this smart value with user condition. For only customer view and that users, user condition will be enough because they can't add any internal comments
Hi @Ezgi Bayındır , I'm sorry it took so long to reply to you here! I wanted to confirm that the `{{comment.isInternal}}` did the trick for me :) Thank you again!
Here's an example of how this looks in the Legacy Automation System:
