Hello Team!
Is there a way to populate the date picker field when a radio button is selected? Please see attached:
If 'Temporary' radio button is selected, another field (Date picker or any desired field) should populate. I tried to do it via Automation but it doesn't work or I'm not sure if I done it correctly. Is there other ways to do this?
The scenario above is required to execute on the ITSM portal used by the customers. Thank you!
Seems like you need a dynamic form. Have you checked this app to see if it will meet your needs?
https://marketplace.atlassian.com/apps/1212161/extension-for-jira-service-desk?hosting=cloud&tab=overview
