Hi everyone,
I'd like to understand how to update a comment via an automated script. We have reports that run and when completed, it would be very helpful to send a link in the comments section of a Jira.
If there is an example or tutorial or any helpful guidance I'd be very grateful.
thanks!
Zak
hello @Zak S ,
It really depends on how/where you run your report.
Without knowing your context, I can point you to :
With more context on your report generation, we might be able to give a better answer.
Hi Robert
thank you for the answer and the options.
I'm running a script from my shell, it carries out a process and when its done I'd want to post a comment with a link to the output of the script.
I guess the rest api is my best way here.
Zak
