How to remove Agile custom fields from project?
Jauer July 9, 2014
I need this to do, so that I'm able to transfer a whole project into a completely other Jira instance. Due to different custom field IDs this is impossible using import project function. So I like to delete them.
Jira 6 is source and target version.
Julia Levcovets
July 9, 2014
Hi, you can disable jira agile and make the import anyway
Jauer July 9, 2014
Thank you that is pretty useful.
Julia Levcovets
July 9, 2014
Julia Levcovets
July 9, 2014
also you can unlock fields and delete them, but greenhopper will lose info and will stop working at all https://confluence.atlassian.com/display/GHKB/How+to+unlock+a+Locked+field
