How to restrict edit permission for a custom field on bulk update?
Thomas Strohmaier
I created an custom option field which is updated by an listener. To avid editing, the field is removed from all edit screens, at last for the relevant projects. So the field can't be edit manually, which works fine.
In bulk update after an search I do can select the field for updating, even if the issues belong to an project which can't edit it.
How can I avoid the update possibility in the bulk update?
Nadir MEZIANI
August 1, 2018
@Alexey Matveevit's not an admin feature
To perform a bulk operation, you'll need the appropriate project-specific permission and the global Bulk Change permission. For example, you would need to have both the Move Issue and Bulk Change permissions to perform the Bulk Move operation.
https://confluence.atlassian.com/jiracoreserver073/editing-multiple-issues-at-the-same-time-861257342.html
@Thomas Strohmaiermaybe you could do it by cutomization of the template file of bulk edit
Alexey Matveev
July 26, 2018
You can not restrict a field on bulk edit. The bulk edit feature is not meant to be for users. It is an admin feature and admins should know what they want to do .
