×I want to retrieve attachments from Jira to share point , when an issue is created in jira, using power automate..
I want to understand how i can use HTTP request to pull the attachments data using Rest API..
If there are any other ways to do this too, please help.
Inside Apply to Each "attachment" - Status should be 303, following Action needs to be set configure run after "has skipped"
hello,
GET an attachment in jira, you can use :
