I'm trying to do a point spread auto calculation for a selection list with smart values.
List values are field multi-select items which users select when they create/edit their tickets.
Example:
Solution Change Type:
- Software
- Network
- Content
- Content in Software
- etc.
Can't get the syntax right. What I want is my value if the item is selected and a zero if it is not selected.
Trigger: When value changes for "Solution change type" change
Action: Edit issue fields > Story Points
Example of desired calculation.
{{#math}}
IF(exists({{issue.Solution Change Type.get(0).value}}),2,0) +
IF(exists({{issue.Solution Change Type.get(1).value}}),1,0) +
IF(exists({{issue.Solution Change Type.get(2).value}}),1,0) +
IF(exists({{issue.Solution Change Type.get(3).value}}),1,0)
I've tried a number of variations but I either end up with ' + + + + +' or
This can be done in one step with a field edit
{{#math}}
{{issue.Solution Change Type.size|0}}
+ IF({{issue.Solution Change Type.join("_").indexOf("CHC Software")}}>=0,2,0)
+ IF({{issue.Solution Change Type.join("_").indexOf("On-Prem Infra")}}>=0,3,0)
+ IF({{issue.Solution Change Type.join("_").indexOf("Content Changes (outside software code)")}}>=0,1,0)
We just added up the values and then found specific items we wanted to count more than 1 point for (giving weight to those kinds of tickets).
Not precise, but good enough.
Thanks!
Hi @Leeland
If I am understanding your question, you want to sum values when items from your multiple-select field are selected AND it appears that some of those values have different summing values. Is this correct? If so...
Yes, you are correct: get() returns a value from a smart value list, and for your field it will only return selected choices...not the entire list, 0 to n-1, with a setting of "on" and "off".
So you probably have limited options for Jira Server automation:
Best regards,
Assume I want to do it the really hard way. Can you give me a snippet to make that work? This is something we can let take a long time in the background and doesn't happen very often.
Okay, perhaps something like this:
I have also seen community posts where people "bundle" data, storing the incrementor in the field definition and summing them later. (DBAs dislike that :^) For example:
You may then get all of the values and sum them in one step in a rule, using a regular expression to extract the values and list functions to sum them up.
Good luck!
Thanks, that almost works. I built this:
But, Story Points is being set to 3 instead of the expected 4.
I might have figured out a single pass with this style:
{{#math}}
Yup, that second way should work also. In that approach, you can set the Story Points in one step and no re-fetch calls are needed.
Make sure you test the edge cases of no values and all values selected to confirm you get what you wanted.
__Bill
