How to set behavior between two options values in same checkbox using Groovy
Ibrahim Mohammed November 3, 2021
Hi Team,
How to set behavior between two options values in same checkbox where selecting one option should hide another option in checkbox.
For eg: let's say a checkbox contains options A,B,C etc
B should hide initially and only after selecting option A then B should appear.
How to achieve this functionality in groovy?
I tried with dynamic forms plugin but i could not find success.
Tessa Tuteleers
Hi @Ibrahim Mohammed ,
little late but I just came upon your question looking for my own - different answers.
Did this work out for you in the end?
If you would still be looking for this, you can play with showing options on a checkbox, and check the values selected for checkboxes. Combining those two should fix your issue.
Please let me know if you still need help with this.
- Tessa
