Hello dear community,
I am having trouble writing an automation that is supposed to clone Epics together with their User Stories, Bugs, etc. The cloning of the Epic works as expected, but when it tries to also clone the User Story, I always get the error message:
"Error creating issue Time Tracking is required. (timetracking)"
The branch for this operation looks as follows:
mandatory fields are "Summary", "Description" and "Original Estimate"
What am I doing wrong?
After trying a lot of things, I finally found an answer. It somehow doesn´t work if you try to copy it via the built in functions, but it does if you use the following JSON snippet:
@Jano_ANGSTEN is there anyway that you can post an image showing exactly what the audit report says for not only the user story but all the other items as well? Including the epic?
