Incoming Webhook error "no issue from webhook"
David Mack
December 13, 2022
What I would like to create is a webhook to push issues from one JSM (JSM1) instance to another JSM (JSM2) instance when the issue is moved to a particular queue.  I get an error of no issues from webhook on the incoming webhook (JSM2). Any help would be greatly appreciated.
This is what I have set up:
JSM1
JSM2
This is the output:
JSM1
JSM2
Vamsi Kandala
December 22, 2022
Hi @David Mack
The instance in JSM2 is expecting the issue details either as part of the webhook url from JSM1 or in the body.  Refer to the example given above in one of your screens where it shows how to pass the issue details (if single or multiple).
Looks like you have not provided any issue details and so it is giving that error.
Hope this helps.
Vamsi
