Is it possible to fill an assignee with Automation for Jira (smart value) based on a project role.
Situation:
If it is an issue with value X in Custom_field Y, the assignee must become the person in project role manager.
If it is an issue with value Z in Custom_field Y, the assignee must become the person in project role testmanager.
The project roles manager and testmanager are present in the various projects, with 1 user in each role in each project.
The automation rule is for multiple projects
Hi Marco
Yes, you can build a rule in Automation for Jira that does that.
Create a rule based on Field value changed trigger.
Then add an Action component for Assign issue.
Choose Assign the issue to: User in a role
Then just follow through with the rest of the values needed.
Thank you!!
Sorry for digging this post back up but how would I go about adding all users of a Project Role to any other multi user field?
In particular I am looking to use Automation for Jira to set the Approvers to all members of a project role, but https://support.atlassian.com/cloud-automation/docs/jira-smart-values-projects/ seems lacking.
Many thanks in advance!
Hi @Fabian Dengel - Please create a new question so that more people can see it and answers can be tailored for your exact need.
