Is it possible to track how long a task was in status "in review"?
Aleksandra January 30, 2018
Hello! please tell me, is it possible any way to track how long a task was in status "in review", ignoring the statuses "open" and "resolved"? Thank You!
Krisztian Kovacs
January 30, 2018
Hi there,
are you looking for the sum of time spent in various statuses? Or just the time spent 'in progress'?
Here is one random thing you can try: https://confluence.atlassian.com/jirakb/how-to-use-average-time-in-status-gadget-776998092.html
Or use Scriptrunner which seems scary at first but it's really useful: https://community.atlassian.com/t5/Jira-questions/Time-spent-in-In-progress-Open-statuses-HOW-TO/qaq-p/73343
And this is an overview of the add-on: https://scriptrunner.adaptavist.com/latest/jira/quickstart.html
With this last one, you can create fields that contain whatever you'd like, in your case maybe 'time in status' or 'time in statuses', then you can filter them, create a filter subscription or do whatever notification you'd like.
I hope this makes sense, let me know if it's working for you.
Krisz
P.S.: if you think my answer is useful,
please consider accepting it.
I'm going for the high score.
Lime Trees
please check our free add-on Status History, which shows history of all statuses on issue.
For more sophisticated functionalities, you can look at Status History PRO.
Lime Trees Support Team
