Issue Auto-generation in project B when an issue status changed in Project A
Christopher Kolb June 27, 2017
I'm trying to find if there is a method or jira extension/addon which will allow an issue to be automatically generated in a project, triggered by the status change of an issue in another project.
ie.
Project A: Issue 1, Status: Escalated-> Approved
Project B: Issue 1b
 The current strategy is to create a new issue in the second project and link the issues manually.
Nic Brough -Adaptavist-
June 27, 2017
There are add-ons which provide functions that do "create another issue" as post-functions.
I'd use the script-runner, as I've almost always got it to hand, but there are others in the marketplace that do it.
Thanks Nic, I'll look into it
LarryBrock
We have used the "Create on Transition" add-on in a number of workflows with great success.  Nic is also right - "Script Runner" for JIRA can do the job well also.
