JIRA 4.3.4 advanced search fix versions only listing as field numbers in the autocomplete dialogue
Dave Donnelly _Sensata_
October 3, 2011
Attempting to include "fix version" as a query term in a search string. The autocomplete lists the fix versions as numbers such as:
0x4400
0x4401
0x4402
etc
and also
releasedVersions()
unreleasedVersions()
Re-indexing does not solve this problem. Only solution is to go into simple search and select the project and fix versions and then switch to advanced searching. This still doesn't render the fix version names but it picks the corresponding numbers for you... not ideal :(
Any ideas what's wrong here?
Dave
March 8, 2012
Turns out this is a real bug.
Atlassian have raised https://jira.atlassian.com/browse/JRA-27462 to track its resolution.
Please vote for it.
Dave
February 15, 2012
Off to raise a helpdesk request with Atlassian as nothing is forthcoming here. Will post fix if available.
