Currently I am using JIRA 4.4.5 and I notice that built-in Workflow Designer is not saving diagrams in a right way..
When I am creating a new workflow I am always saving the layout.. But when I go to the issue that have this new workflow and I want to view it, always it is different then when I've saved it using the tool.. Mostly the transition lines are broken and sometimes statuses are not on the position that they supposed to be.. for example.. I am creating a straight line but after I save it and view it is poiting to other place..
However when I am saving the picture to my computer then its looks ok..
Did you notice the same? If so.. Is there any workaround that could fix this issue?
Thank you very much for your support!
Mirek
Yes, this is a bug reported already to support. Someone reported yesterday if you use a polyline with at least four points, the layout does not mess up as bad.
I was just doing that! :>)
