JQL not working in automation (but work in normal search)
christophe demez
I use the JIRA automation and I use a JQL that works fine in the normal search console, here it is:
category = "All Initiative Projects" and issuetype = Epic
But, when I use the automation and create a "Scheduled" + JQL it returns 0 results.
Do you have any idea of the problem and how to solve it?
2 accepted
3 votes
Callum Carlile _Automation Consultants_
Hi @christophe demez
Is your automation rule scoped to a single project which falls outside of the JQL? In order to action all issues in all projects within that project category, you will need your rule to be scoped to those projects
christophe demez
You're right @Callum Carlile _Automation Consultants_ , if I create a "global" rule it works. Well see ;-)
