JSM Project Automation - Updating a numeric custom field with the value from a smart variable
Daniel Wright September 19, 2025
Hi All,
I've tried scanning through the community pages but I can't seem to quiet find the right answer yet.
With JSM customisation I want to be able to put a points value to each ticket. I'm referencing another fields selection to determine how many points the ticket will get assigned to it, with this value added to a custom field of its own (which I will later use to the order tickets in filtered list view or queue).
I have a automation rule that get the points value puts it into a smart variable, thats working great (outputs to comment confirms I have the number value) and I'm ready to assign this to the custom field setup.
Problem is that my points custom field (customFieldId_144) it is not available in the edit work item drop down, think because its a numeric value custom field?
I've tried reading up on the more fields section and providing the JSON but I'm going around in circles now as anything I take to copy and paste to try its just coming back with JSON error warnings.
Appreciate any support from the wider community on this one
4 votes
Matteo Vecchiato
September 19, 2025
Hi @Daniel Wright ,
Thank you for your question.
Numeric fields are listed in automation update fields, so the cause is other, like:
  • Have you checked the custom field context? Maybe it is not applied to a specific project you are testing or it should be a global field
  • Check if the field is inserted in the edit screen (really this shouldn't affects, but just in case)
  • Refresh the automation webpage, it the field has been created after opening the automation, not all part are refreshed.
I hope it helps.
Regards
Daniel Wright September 20, 2025
User error thank you for the guidance above, no more midnight automation coding for me :)
Like Matteo Vecchiato likes this
Oleksii Melnyk _MOY Apps_
September 20, 2025
Hi @Daniel Wright
Jira can sometimes give errors about the JSON format.
Double-check that you're filling in the fields correctly according to the documentation. Atlassian doc: Advanced field editing using JSON
For Number custom field it must be like:
"customfield_11444" : 664
So your JSON with smart value must be like
{"fields":{"customfield_123":"{{smart_value}}"}}
where {{smart_value}} = 1000 (for example)
