Jira Assets attribute object reference multi select
Michael Frade
In Jira Assets, if you have an attribute that is a reference to another object, is there a way to have multi select.  So if the attribute is a linked to an employee object schema and you want to be able to associate multiple employees for that attribute as like a POC, is that possible?
Mikael Sandberg
Yes, that is possible. What you need to do is set the cardinality to unlimited, similar to what I have done for the attribute catalog:
Michael Frade
I went round and round. Thank you!
Like Mikael Sandberg likes this
Özlem Bilican
October 24, 2024
Hi, when importing assets with csv, what format should we write it in to the document?
I found :)
in CSV document:
Name
Environment
Test App
Test||Production||Development
 Jira import AQL:
Label IN (${Environment${0}})
