Jira Automation: Creating multiple linked issues based on Multi-Choice Custom Field
Mohamed Sarjun February 20, 2025
Hi guys,
I need help with a Jira automation rule for a project that has the following issue types:
Request
Epic
Story
Sub-task
I have an Issue Collector that creates a Request issue, which includes custom fields related to Epic and Story issue types.
Requirement:
When a Request issue is created, I want an automation rule to:
1. Extract values from a custom field called Category Type (a multi-choice select list with multiple options).
2. For each selected value in Category Type, create:
A Epic issue (linked as a child to the Request).
A Story issue (linked as a child to the respective Epic issue).
3. Ensure all issues are linked properly to maintain the hierarchy.
I have already set up an automation rule, but it is not working as expected:
I am using branching and smart values, but the branch rule is not getting executed. Error: Unable to run this component
rule1.pngrule2.pngrule3.pngCould someone help me identify what's wrong and suggest the correct smart values or rule structure?
Sarjun.
2 accepted
Bill Sheboy
February 20, 2025
Hi @Mohamed Sarjun
Starting with the original rule you show in the question, when you created the variable, that leads to a text value such as this:
Option A, Option B, Option C
Where using {{issue.customfiled_12663.value}} automatically added a comma-space delimiter.
To then use that to feed the Advanced Branch, the values must be split back into a list:
{{categoryType.split(", ")}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#split-String-separator-
As an alternative, you could use the smart value directly to feed the branch:
The values in the branch will be the text of the options selected for the field.
Evgenii
Hi, @Mohamed Sarjun
Welcome to Atlassian Community
What is returned in variable {{CategoryType}}?
And if I understood right, you are trying to receive list of values, and work with each of them?
In case of list values it's better to use list iteration, like described here:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/
It will iterate through all elements in field value and use values in actions.
Made an example
Hi @Evgenii
Yes, you understood it correctly. The variable {{CategoryType}} holds a list of values selected in the Category Type custom field (which is a multi-choice select list). My goal is to iterate through each value in this list and create separate Epic and Story issues for each selected value while maintaining the correct parent-child hierarchy.
However, I am facing issues when trying to extract and work with individual values from this list within the automation rule
Evgenii
I made an example, attached images above. I think, it's your case, and it will solve your problem
I tried implementing the same branching rule as suggested, but I am still encountering the same issue: "Unable to run this component." It seems like the iteration is not working as expected in my case.
Are there any additional steps I should take to ensure the list values are properly processed within the branch?
