Hi all,
I would like to start and close my Epics automatically by working on the epics's issues alone.
i.e.
* when I start the first of its issues, the Epic should be transitioned to a certain status in its workflow
* when I close the last of its issues, the Epic should be closed, too.
How can I do this w/ Jira automation?
Hi @Ingo Mohr
Yes, you could do this for specific status values or generically (with statusCategory). I encourage you to experiment and try both ways to learn about automation rules.
For example as generically, ignoring issue status:
Thanks @Bill Sheboy
I had to fiddle around a little bit - but I could get the rule up and running. :)
@Bill Sheboy - I wonder if what you wrote here could be used to solve the issue we are trying to solve in the other post?
Hi @Adam Ziecik
I do not believe so, as this approach uses the Lookup Issues action, which is not supported by the Server/Data Center version you are using.
Please see the other thread for my additional suggestion.
Hi @Ingo Mohr ,
If you have our JQL Search Extensions, you can create a scheduled daily or hourly rule to find the epics that need to be transitioned:
type=Epic AND statusCategory="To Do" AND (issuesInEpicToDoCount>0 OR issuesInEpicInProgressCount>0)
You can find more examples in the documentation.
Thanks!
Thank you @Daniel Turczanski for suggesting your plug-in. It's not my Jira instance, however. But still: good to know :)
Your automation should look something like this:
And if you look in the library you will find an automation that will close the epic once all stories are done.
Thanks @Mikael Sandberg !
This worked - and I think this helps me get going too for other rules.
### Suggestion
However, while I was editing the rule, I asked myself why there isn't a feature to specify rules as a script - maybe directly with a Bitbucket Repo link - so that I can maintain rules in Bitbucket (with tags) and then refer to the tag of a rule script in Bitbucket...
Is this something you can take back to the team - as a community leader?
Ingo
