×Hi everyone!
I'm now struggeling for a while with a certain automation:
I automated process where several subtasks get created under the trigger task.
I now want to link each subtask only with the one before and set it to "has to be done before"
Like: Subtask 1 --> Subtask 2 --> Subtask 3 etc.
I already found a similar question of another user here but the outcoming result links all subtasks with each other.
Also: I can only link issues to the trigger or recently cerated issue. Neither to a smart-value nor to a key. Is this normal behavior?
Thanks for your thoughts and ideas!
- Jürgen
Hello @Jürgen Heckmann
To link the sub-tasks, you will need to set the linkage in the Automation rule for all sub-tasks except the first one. Please refer to the below screenshot for reference.
Note: In my environment, the required link type is not available and hence, I have used a different one.
Please feel free to share any queries.
Kindly accept the answer if this helps resolve the scenario.
Hi @Gaurav ,
Thank you for your fast reply. This was my inital solution idea aswell.
Unfortunatelly, this runs into the following error:
The error confuses my since I can manually link the tasks once they are created.
My task creation looks like this:
This is interesting and odd but something which I have experienced previously!!
I can think of a couple of ways to check this out:
Kindly try these alternates and share your input. I would be really interested to see how it works out for you.
Hi @Gaurav ,
Thank you for your ideas. Unfortunatelly it didn't help. But I figured out how to solve it:
Apparently in the Create-Task Automation Component only fields can be acessed, which are also available in the corresponding Screen for creating tasks manually.
Once I added the "Linked Issues"-Field to the screen (see screenshot) the automation worked.
I now run into another but much smaller issue. It seems that during an if-condition created subtask is not being considered as "recently created issue" but the last task before the condition.
Here is my Automation:
All "create a new subtask" actions in the if conditions are not considered but a link to the last subtask before the condition starts, is created.
the automation scheme (with the occuring error) looks like this:
Do you have an idea how to solve this issue?
That appears to be a known behavior: the {{createdIssue}} and {{createdIssues}} contexts are not updated in the main flow when an issue is created within a conditional part of the rule:
https://codebarrel.atlassian.net/browse/AUT-1090
Thanks @Bill Sheboy for sharing the details!!!
@Jürgen Heckmann as Bill mentioned this is known behaviour. I can suggest breaking the rule into parts and triggering the subsequent part from the previous one. This is something which I have tried and relies on the logical condition used for breaking and triggering.
Hope this helps!!
- GG
Hi @Gaurav and @Bill Sheboy ,
Thank you for your good support! I will then create a workaround as suggested!
Jürgen
