Jira Automation Slack Messages
Kevin Porsolt
January 9, 2022
Our Product Dev Team uses Jira Automation for internal operations around sprint management. These rules are pretty critical to our success, so it is helpful to know when a rule or set of rules are failing. I know that the user can be notified via email if a rule they created fails, but does anyone know if Slack messages can be sent when a Jira automation rule fails? Our team works predominately in Slack, so these would be more beneficial than emails. Thanks!
Charlie Gavey
January 10, 2022
Hi Kevin,
I’ve linked your suggestion to a related feature request, which counts as an upvote for this ticket:
https://codebarrel.atlassian.net/browse/AUT-12
Thanks for using Automation!
Charlie
Kevin Porsolt
January 11, 2022
Hello Charlie, thanks for the response. I see the ticket you linked this to is for general automation error emails that we get as a default. Is there a separate ticket for tracking expanding automation error messages via webhooks? Thanks
