Jira Automation setting Team field based on project
Deleted user March 28, 2023
Afternoon all,
We would like to use automation to set the team field based on the project the issue is created in. I could add an if for each project (50plus), but was wondering if there is a quicker, smarter way to do this?
Deleted user March 30, 2023
So a very ugly workaround is to add the team value to the project name and then set a smart value by using substring on the project name to get the team number.
Not the best solution. is there a way to retrieve the project description field?
or
in the json, could I add a lookup list e.g. list of project key and the team number it relates to?
so for example if project key = ABC then the team value from the look up list e.g. ABC = 123, would be used to set the
for now I have settled for using the project description field which I prefix with a special Char to identify the team id saved in the project description field. You can retrieve data from this field using {{project.description}} as a smart value.
Michael Wohlgemuth
March 28, 2023
Greetings @[deleted] .
what field type is the "team field"?
regards
It's the field created by Jira for plans and can't edit or view details as it's locked. If I query the field in JQL, the drop-down options are team names as entered, but once selected a numeric value is returned.
