Jira Monitoring using AppDynamics
Deleted user May 21, 2019
How and what metrics to monitor in Jira using AppDynamics
Diana_Architect_ZigiWave
@[deleted]
I wonder if you had any particular data in mind? Also, are you using a tool to connect the systems so you could monitor metrics? In case you have once more the need to integrate the two systems, feel free to check out ZigiOps. It's a no-code integration platform that allows the transfer of default and custom fields between the systems and syncs them in real-time. It reads the schema dynamically and can transfer any fields. Feel free to explore it and if you feel it could help you with a potential future project, you can book a technical demo to see it in action.
Regards, Diana (ZigiWave team)
