Jira and power bi integration manually
Shon John Mathew
June 2, 2022
Is there a way manually to integrate/get all data from jira to power bi without using
jira-power bi connector.
Anna Odrynska - Alpha Serve
Hi @Shon John Mathew ,
I guess, using API will be manual? Take a look at the discussion here: https://community.atlassian.com/t5/Jira-Service-Management/How-to-connect-power-bi-with-Jira-cloud/qaq-p/1757343
As @Andy Heinzer mentioned above, using add-on will be an option as well.
Anna
Andy Heinzer
June 3, 2022
Hi
I don't know of means to manually integrate Jira with Power BI.  However there are several options within our Marketplace, try this search link https://marketplace.atlassian.com/search?hosting=cloud&product=jira&query=power%20bi
I hope that helps.
Andy
