Jira automation - Multiple layers of issues in 1 rule
Chris F
Hi team,
I'm trying to set up the automatic creation of issues within Jira that would act as a 'service onboarding' checklist. In theory it would work something like:
If an Outcome is created (custom issue type above Epic/Feature)
Then create 4 Epics
For each of those epics
Create 3 Stories/Tasks
I've tried experimenting with a few options to have this all work in 1 rule but I haven't been successful. I could split this off into 2 rules but I was hoping to keep things neat.
Any guidance/help is appreciated.
4 votes
JM Perrot
Hello @Chris F
If the most important thing for you is to keep it in one rule, you can sequence your rule this way:
  • When an outcome is created
  • Then create 1 Epic
  • For the most recently created issue
    •    -Then Create a story
etc...
I hope this can be useful, let me know if it's the case :)
Bests,
JM
Chris F
Brilliant, thanks @JM Perrot
For any future readers who are trying this and are wondering how to then link the Epic to the Story I had to create a Variable that captured the Epic's issue key and then use that as the value for the 'Epic Link' on the Story.
Like JM Perrot likes this
