I have a
What is the smart value that must be accessed to be able to evaluate all removed or added Components after a trigger of Value Change: Components
I thought `changelog.components` but I cannot access `fromString`, `toString` or `name`
I was actually able to sort it:
I was able to add a comment, eg:
Component changed from {{changelog.component.fromString}} to {{changelog.component.toString}}
So it is {{#changelog.component.to}} and {{#changelog.component.from}} to access the single ones probably, will keep posted
Thanks, @Raffaele Litto !!
Looks like they have improved the API so the automation rules can use that. Let's see what they update in the defect/suggestion.
Please mark your own answer as "accepted" as that will help others find this solution in the future. Thanks, again!
__Bill
According to this defect, automation changelog does not work for components and fixVersion fields yet:
Best regards,
Hi Bill, I managed to do that, it seems! I will post it as an answer to my question!
