Jira automation - link issues with same field value
Kim Yap
March 13, 2023
Is it possible to automatically link a new issue to an existing issue if they have the same text field value?
In our Jira service management project, we link issues if they have the same value entered in the summary field. Is there a way to automate this?
Kris Dewachter
Hi @Kim Yap ,
In your automation rule, you will need to use a JQL that will search for matching issues. In this JQL, you have to fetch the field value of the trigger issue with smart values.
Maybe this community topic can help you : https://community.atlassian.com/t5/Jira-Software-questions/Automation-JQL-condition-using-smart-values/qaq-p/1831414
Best regards,
Kris
Kim Yap
March 13, 2023
Thank you so much, @Kris Dewachter ! I was playing around with the JQL condition, but it wasn't returning anything. Turns out I needed to add a branching rule. I followed the automation steps mentioned in the link, it gave me exactly what I needed. Thank you!
Kim
